Home > Message Board > Home Audio > DAC and Transports > DAC output muting relay causing nasty...
Author Thread: DAC output muting relay causing nasty click
Anynamewilldo
Hi. The output relay on my DPA 'Little Bit' is causing a really nasty 'click' over the speakers when a CD is found by my player. Anybody know if the relay itself is to blame, or is some other component failing? Cheers, David Stenhouse
Relevant Product Info
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > DAC and Transports > DAC output muting relay causing nasty... [ « Previous ] [ Next » ]
