Thread: Help Hooking up a subwoofer |
New member Username: El_jay
Post Number: 1 Registered: Oct-04
| Posted on Monday, October 04, 2004 - 12:04 am: |
Hello, I am attempting to hook a subwoofer up to my stereo system. I can't seem to figure it out. Would someone please let me know how they would do it? Below is a link to pictures of the back of the Amp and the Back of the subwoofer controller. http://www.destrung.com/help.html Any help would be greatly appreciated. Thanks!! |
Bronze Member Username: Claudermilk
Post Number: 44 Registered: Sep-04
| Posted on Monday, October 04, 2004 - 02:24 am: |
From the receiver you will use the Subwoofer output in the Preout section. I'm not sure about the subwoofer controller (haven't encoutered that in my limited experience)--but my first guess would the be the From Preamp connections. |
Silver Member Username: Petergalbraith
Rimouski,
Quebec
Post Number: 111 Registered: Feb-04
| Posted on Monday, October 04, 2004 - 11:36 am: |
Jonacio, You have a modern receiver and an older sub that predates the support of subs directly on the receiver. Normally, such a sub "controller" acts as a crossover between a stereo pre-amp and an amplifier, splitting the input signal between low frequncies for the sub and high frequencies back to the amplifier for the main speakers. In your case, you could try fitting a Y doubler adapter on your receiver sub pre-put into the "From pre-amp" inputs on the sub controller. |
Post Number: 2 Registered: Oct-04
| Posted on Wednesday, October 06, 2004 - 12:13 pm: |
Hello Peter Thanks for the tip. I tried that and it still is not working. Do you know anything about the 'servo interface' line on the rear of the sub woofer controller http://www.destrung.com/help.html There is a servo input plug on the subwoofer unit that will receive this cable from the rear of the controller. Should I try that? Thanks again for your help |
Rimouski,
Quebec
Post Number: 117 Registered: Feb-04
| Posted on Wednesday, October 06, 2004 - 01:47 pm: |
Jonacio, I assume that an RCA cable should get connected between the servo interface plug and a similar plug in the sub. It serves as feedback from the sub back to the amplifier to tell the amplifier how the sub responded to a signal in order to correct the response. |
| Posted on Thursday, November 18, 2004 - 08:35 pm: |
What is the best way to hook up two twelves to an 2 ohm stable two channel amp. Would it be series, parrelel, or would it be best to just bridge both of them to the amp. |
New member Username: Guma_1
Post Number: 1 Registered: Jan-05
| Posted on Sunday, January 16, 2005 - 11:27 pm: |
I just got this subwoofer and there doesn't seem to be a power cord or any kind of power source. Is this normal, and if so, what is the proper way to connect? Please help.... |
Bronze Member Username: Usa2k4
Post Number: 36 Registered: Dec-04
| Posted on Sunday, January 16, 2005 - 11:36 pm: |
Roscoe, yours is a passive subwoofer, which means it doesn't have a built-in amplifier. The easiest way is to connect its speaker input terminals to the speaker terminals on the receiver then connect the sattelites to the subwoofer's speaker output terminals. |
Unregistered guest |
| Posted on Wednesday, March 02, 2005 - 05:35 pm: |
I have a subwoofer without a powercord and with tension clamp to hook it up to the receiver, and a receiver that uses a plug type connection to the subwoofer similar looking to an a/v cord plug. Can I use this subwoofer or do I need to get a different one with the three prong plugs? |
Silver Member Username: Usa2k4
Post Number: 125 Registered: Dec-04
| Posted on Wednesday, March 02, 2005 - 06:32 pm: |
If the sub has speaker-level In/Out then you can connected it to the receiver and the satellite speakers to it via the speaker terminals. |
