Thread: Non-powered subwoofer setup with Denon receiver-please help!!! |
New member Username: Miggedymack
New York City
Post Number: 1 Registered: Oct-04
| Posted on Saturday, October 02, 2004 - 05:29 pm: |
Hi all, Thanks in advance for the newbie question. I seem to have successfully setup my Denon AVR-2105, except for the subwoofer. I'm not getting any sound out of it. Nothing. I have an NHT non-powered sub SW2P and a NHT MA1A amp that I inherited from my in-laws. In the Denon manual, it shows the sub pre-out to a powered subwoofer. Can I still use this sub if I have an amp powering it? If so, how? Should I use the EXT-in or the Zone 2 source instead? Thanks in advance! |
Silver Member Username: Petergalbraith
Rimouski,
Quebec
Post Number: 105 Registered: Feb-04
| Posted on Saturday, October 02, 2004 - 07:08 pm: |
Go from the receiver sub pre-out to your sub's amplifier (possibly using a Y connector if it's a 2-channel amp) and go from that to your sub. |
New York City
Post Number: 2 Registered: Oct-04
| Posted on Sunday, October 03, 2004 - 09:18 pm: |
Thanks, Peter. I think the amp might be broken, because this is how I have it set up. Know where to find a good, cheap amp? How much $$ am I lookin' at? |
Rimouski,
Quebec
Post Number: 110 Registered: Feb-04
| Posted on Sunday, October 03, 2004 - 11:37 pm: |
James, If you think the NHT amp is faulty, try another pre-out from the Denon (to make sure it's not the Denon's sub pre-out at fault) and also make sure the sub pre-out level is not set to -10 dB or something on the Denon. If the amp is still not outputing anything, try driving the sub from the Denon speaker outputs (if the sub has a crossover). Then it should output something, confirming that the amp is the problem. Then look for a used power amp! Doesn't have to be too high quality for a sub.
