Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through February 12, 2004 > Hiding Cables under wall2wall Carpets
Author Thread: Hiding Cables under wall2wall Carpets
Username: Homedesign
Post Number: 32
How can this be done with installed wall-to-wall carpet? Is there a tool to send the cable from a small cut in the carpet at one end of a room to the other side of the room, for insance?
Username: Edison
Post Number: 290
You can get flat cables that doesn't show up as much, and run it along the wall if you really want to hide it.
www.accessories4less.com has ixos flat cable.
Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through February 12, 2004 > Hiding Cables under wall2wall Carpets [ « Previous ] [ Next » ]
