Thread: Just got a Dual CS 503-1 and have some problems |
New member Username: Exmonkey
Post Number: 1 Registered: Sep-04
| Posted on Thursday, September 30, 2004 - 02:46 pm: |
Let me start by saying - i know very little about turntables, but I recently decided to get something to play my old vinal, and picked up this Dual CS 503-1 on Ebay. I plugged it into my Cambridge Audio A1 amp phono sockets with the expectation of sitting back and listening to some great sounds - unfortunately it seems very quiet (and tinny) and plays at around 35rpm (rather than 33). I have checked the belt and the two wheels and all seems fine. Any thoughts anyone? I hope I havnt bought a duff turntable. Ex |
Post Number: 2 Registered: Sep-04
| Posted on Saturday, October 02, 2004 - 09:54 am: |
update: I found outthat my integrated amp requires an optional phone sound stage for turntable use. I have now fitted it and it sounds fine - the pitch is still to fast though. Does anyone have one of these turntables? Is there a pitch adjustment screw or similar located anywhere on the unit? |
J. Vigne Unregistered guest |
| Posted on Saturday, October 02, 2004 - 05:00 pm: |
Often cleaning the belt and the drive rim under the platter will solve this problem. Use Isopropyl alchohol and remove the platter by taking the C-clip off the center spindle.
Silver Member Username: Disco_stan
Minnesota
Post Number: 170 Registered: Dec-03
| Posted on Wednesday, December 01, 2004 - 12:30 am: |
Marc would you have any specs on that table? |
New member Username: Dualref
Spring,
Texas
Post Number: 1 Registered: Mar-05
| Posted on Thursday, March 31, 2005 - 11:10 am: |
You can look at the Dual Reference Website, they have all the specs for most of the Dual turntables. http://www.dual-reference.com They also list parts suppliers as well as repair facilities. |
