Thread: Good In-wall surround system? |
New member Username: Will_i_am_1
Post Number: 4 Registered: Sep-04
| Posted on Wednesday, September 29, 2004 - 02:22 pm: |
This may be a stupid question, but what is the difference between an integrated and a power amplifier. Also, if I have a component system with a tuner, amplifier, and cd/dvd plaver, do I need a preamp? Do the tuner and cd/dvd player hook into the preamp which hooks into the amp and them out to the speakers? Do I need a special surround sound unit after the amp to get surround sound effects? What is the best way to handle all of that? Thanks in advance, Will |
Relevant Product Info
Bronze Member Username: Bleustar
Pensacola,
Florida
Post Number: 100 Registered: Jul-04
| Posted on Wednesday, September 29, 2004 - 03:03 pm: |
The receiver has a amplifier, tuner and processor. The amplifier has no processor (volume knob, bass/treble etc...and no tuner. The tuner has no amplifier and the integrated amplifier essentially is an amplifier and processor without a tuner. Sounds a little like who's on first! |
Post Number: 5 Registered: Sep-04
| Posted on Wednesday, September 29, 2004 - 04:35 pm: |
That actually makes a lot of sense... thanks! So I either need... a reciever (tuner/processor/amp) or a tuner + an integrated amplifier (processor/amp) or a tuner + a preamp(????) + a power amp Can you run a receiver or integrated amp into a power amp for more power, or will that blow something up? Also, if you have three seperate components tuner, preamp, power amp... do you need something extra for surround sound? Thanks, Will
Silver Member Username: Rh1
Post Number: 161 Registered: Jun-04
| Posted on Wednesday, September 29, 2004 - 05:00 pm: |
yes you can run a power amp and receiver...the integrated amp/power amp combo would not be necessary as the integrated would contain the power amp...you would not need anything for surround sound if you had tuner/preamp/power amp assuming you have power for multi channels out of the power amp |
Post Number: 162 Registered: Jun-04
| Posted on Wednesday, September 29, 2004 - 05:01 pm: |
oh and the preamp would have to be multi channel too, not stereo |
Post Number: 163 Registered: Jun-04
| Posted on Wednesday, September 29, 2004 - 05:03 pm: |
Or you could just go with a a/v receiver as you mentioned |
