Thread: Ceiling speakers amp ? |
New member Username: Ron6962
Post Number: 1 Registered: Sep-04
| Posted on Wednesday, September 29, 2004 - 12:13 pm: |
I have tried two different receiver/amps to drive 6 pairs of ceiling speakers. One Sony and one RCA, both 500 watt systems. They work for a while, then either blow an internal fuse (Sony) or give me "amp err" (RCA) error. The user guides do not help. Any suggestions? Thanks. |
J. Vigne Unregistered guest |
| Posted on Wednesday, September 29, 2004 - 04:20 pm: |
What type of switch box and volume controls are you hooking between the amp and speakers?
Post Number: 2 Registered: Sep-04
| Posted on Wednesday, September 29, 2004 - 08:29 pm: |
Thanks for the response. I do not have a switch box....just a separate volume control in each room for each set of speakers. Most of the time the volume is off in all but 1 or 2 rooms. I have never tried running all the speakers at the same time, but would not usually want to do that anyway.
| Posted on Thursday, October 07, 2004 - 04:35 pm: |
You need impedance matching controls or switching. Or you need to get creative with the whole parallel/series thing. If you're running six speakers in parallel, you're probably giving the amp a heart attack because it's "looking" at almost a dead short. |
Post Number: 3 Registered: Sep-04
| Posted on Friday, October 08, 2004 - 12:08 am: |
Bingo! Thank you so much for the advice. I have now determined that is exactly my problem. The individual volume controls were not impedance matched appropriately for my amp. Thanks for the response. |
