Home > Message Board > Home Audio > DVD-Audio & SACD > Archive through November 02, 2004 > Coaxial or fiber optic with dvd
Author Thread: Coaxial or fiber optic with dvd
Username: Gticehockey
I have a H/K 630 reciever and was wondering should i use a fiber optic cable or a coaxial with my dvd player?
Relevant Product Info
Username: Myrantz
Post Number: 702
George,
Either is perfectly okay if you are allowing the reciever to do the decoding, however seeing as you are in tha DVD-Audio & SACD section, if you are relating your question to these formats then you would be using the analogue outs of your DVD player to the analogue inputs of your receiver.
Username: Bleustar
Pensacola, Florida
Post Number: 98
Assuming we are not talking DVD Audio or SACD, what would be the audible difference between the two connections?
Username: Sem
New York
Post Number: 263
Should be none to speak of.
Username: Bleustar
Pensacola, Florida
Post Number: 101
What is the advantage of the fiber optic cable outside of less exposure to elements at point of contact?
Username: Arnold_layne
Madrid
Spain
Post Number: 144
Optical cable is considered immune to electric and magnetic interference.
Username: John_a
Post Number: 2179
George,
I agree with all the above replies, and think you are in expert company here. If still in doubt, and you'd like some more points of view, there was a long and heated discussion of this issue on Coaxial Digital Connection Vs Digital Fiber Optical Connection?
Madrid
Spain
Post Number: 152
I personally prefer coaxial. Simply sounds better on my equipment.
Here's a negative opinion on optical (Scroll down to Toslink):
http://www.audioholics.com/techtips/specsformats/audiovideoconnections.php
Home > Message Board > Home Audio > DVD-Audio & SACD > Archive through November 02, 2004 > Coaxial or fiber optic with dvd [ « Previous ] [ Next » ]
