Thread: Whats a good and cheap sub for a small 10X15 room? |
| Posted on Tuesday, September 28, 2004 - 12:36 pm: |
I am looking at hsu, svs and velodyne. velodyne cht10 seems to fit the bill. any other recommendations? thanks |
Relevant Product Info
Bronze Member Username: Petergalbraith
Rimouski,
Quebec
Post Number: 83 Registered: Feb-04
| Posted on Tuesday, September 28, 2004 - 01:17 pm: |
At the Velodyne CHT-10 price point (just below US$300), I'd go for the Hsu STF-1. I haven't heard the STF-1, but I have heard the CHT-12 and I own a STF-3. Huge difference. |
Bronze Member Username: Maximo
Post Number: 19 Registered: Jan-04
| Posted on Wednesday, September 29, 2004 - 07:17 pm: |
The cht-10 can be had for under $200 at onecall.com. But, it really depends on how much you want to spend. If you can afford it, then the Hsu subs is the way I'd go. However, considering the price, onecall has an extremely good deal on their Velodyne CHT subs. |
Rimouski,
Quebec
Post Number: 97 Registered: Feb-04
| Posted on Wednesday, September 29, 2004 - 09:14 pm: |
Interesting find Maximo. They also have the heavier Velodyne DLS4000 (60 lbs Distortion Limiting System 12 Inch Powered Subwoofer) for US$401, which seems like a good price. It really depends on the budget! :-) |
