Thread: SACD Question |
Bronze Member Username: Rickypearson
Post Number: 46 Registered: May-04
| Posted on Saturday, September 25, 2004 - 10:38 pm: |
Hey GUys Do u think you could tell me what a SACD is and what advantages they Have or cds Thanks!! |
Relevant Product Info
Gold Member Username: John_a
Post Number: 2130 Registered: Dec-03
| Posted on Sunday, September 26, 2004 - 01:05 am: |
Super Audio Compact Disc. Advantage to consumer: Greater detail, better sound. Advantage to industry: something to boost flagging CD sales; copy protection - you cannot "rip" files. See also Twilight of the Compact Disc. |
Silver Member Username: Arnold_layne
Madrid Spain
Post Number: 137 Registered: Jun-04
| Posted on Sunday, September 26, 2004 - 08:22 am: |
SACD is a "new" technology for digitalizing, here's a basic comparision: CD: Sound pressure is represented by 16 bit number (0 - 2^15), 44.100 times per second. SACD: 1 bit indicates if sound pressure goes up or down, 2.822.400 times per second. Hence, SACD can provide a much more precise digital representation. IMO a noticeable improvement for vocals and acoustic instruments, sounding more natural. Also, SACD can be 5.1 surround. This means more details in complex music. Cheers AL
Silver Member Username: Myrantz
Post Number: 694 Registered: Aug-04
| Posted on Sunday, September 26, 2004 - 02:28 pm: |
Arnold is right, SACD recordings are in stereo or stereo/multi-channel, and the hybrid discs have a 'CD' layer also enabling playback on a standard cd player. IMO, Super Audio Cd's and DVD-Audio are a very postive step on the road to perfect audio sound. |
J. Vigne Unregistered guest |
| Posted on Sunday, September 26, 2004 - 04:17 pm: |
Arnold - If sound pressure is the only item measured and therefor repesented how do we know what frequency(s) are on the original? |
Madrid Spain
Post Number: 138 Registered: Jun-04
| Posted on Tuesday, September 28, 2004 - 05:06 pm: |
To be precise, I should say "air pressure". Sound is pulses/contractions of air reaching our ears, the result of horisontal push-pull movements of speaker membrane (or whatever source). The magnitude of these air pressure changes determines how strong is the sound. The amount of pulses per time unit determines the sound frequency, i.e. high or low tone. So PCM is roughly about representing current air pressure by a binary number (more bits => increased precision is possible) at a certain sample frequency (more sample KHz => higher sound KHz can be represented). DSD (SACD technology) represent unitary changes (up or down 1 unit) of air pressure. Basically doing the same job as PCM, but DSD does not consider whether the air pressure change is small or large. Therefore sample rate must be very high, so that a large change can be represented by many small changes. Cheers AL |
| Posted on Tuesday, September 28, 2004 - 09:22 pm: |
Wow, I've never seen anyone try to describe DSD in only three sentences. So, if you're saying "air pressure" (are we talking P.S.I.?) represents frequency, I still don't see, in your description, what measures "sound pressure" or amplitude of a frequency. Sorry, just trying to clarify.
Madrid Spain
Post Number: 141 Registered: Jun-04
| Posted on Tuesday, September 28, 2004 - 10:33 pm: |
Actually, I think the air is moving back and forth, so we have maximum and minimum pressure levels. The concepts are then: - Frequency is how often maximum pressure is reached. - Amplitude is the difference between maximum and minimum pressure. It is easier to visualize if the horizontal air movements are transposed into a curve diagram of air pressure (vertical axis) over time (horizontal axis). Just as the common picture of a sine wave, which in acoustics is no more, no less than a pure tone. Digital representation is about plotting this curve. PCM describes the vertical position at each instant of time (how high is pressure). DSD on the other hand just tells if the position is higher or lower than at the previous instant of time (pressure change). It is also important to differ air pressure change frequency (how often there are pressure peaks)from digital sample frequency (how often pressure is measured). Cheers AL
Madrid Spain
Post Number: 142 Registered: Jun-04
| Posted on Tuesday, September 28, 2004 - 10:51 pm: |
Just a couple of precisions: "Sound pressure" is formally used as a measure of energy (air pressure) arriving to a surface. "Air pressure" is in this context relative to static atmospherical pressure. |
Bronze Member Username: Bleustar
Pensacola,
Florida
Post Number: 97 Registered: Jul-04
| Posted on Wednesday, September 29, 2004 - 09:24 am: |
Thanks Arnold for the lesson. I love reading about this in a way that is not so (text book). |
Madrid Spain
Post Number: 145 Registered: Jun-04
| Posted on Wednesday, September 29, 2004 - 08:15 pm: |
No problemo - the more we all learn about these issues, the better we understand why CD was just a step on the way. Another way to answer the original question (Ricky, are you still there?) is to measure and describe how the different formats actually sound. There is a lady who has performed some interesting "spectral and dynamics comparision": http://users.bigpond.net.au/christie/articles.html Heavy duty because of her cientific approach, but IMO worthwile read trough to see the conclusions. Cheers AL |
