Thread: Harman kardon FL 8385 good or bad? |
New member Username: Gticehockey
Post Number: 2 Registered: Sep-04
| Posted on Thursday, September 23, 2004 - 10:47 pm: |
Im putting together a home theater system and wanted to get a cd changer. I have a harman kardon 630 reciever and was looking at the HK FL 8385 cd player.Ive heard that its amazing from everyone when its works. Some people say they dont work right a lot of the time any oppoins?
Silver Member Username: Gman
Mt. Pleasant,
SC
Post Number: 610 Registered: Dec-03
| Posted on Friday, September 24, 2004 - 11:55 am: |
Any electronics with moving parts are more likely to have problems than those that don't. I am sure single play cd players from the same manufacturer will always have a lower percentage of problems. The above being said, the carousel format of cd changers has been around long enough that it should last a long time (as long as you are careful about loading discs). For a unit that lists for $299 and can be gotten for under $200, it is hard to complain about it under any circumstance. If you like multiple disc players, I am sure it is as good as any at the price point. I might prefer a comparable Sony, but if you want matching components go with the HK. Any better specs a Sony might have would be inaudible anyway. The only audible difference will be in how quiet the machines are when they go to the next cd in the carousel. Not a big deal. The cd technology has been around for so long that they are basically commodities. As long as you like the remote and don't mind that it has a digital coaxial connection with no optical one--go for it. The coax will sound just as good--as long as your receiver has a coaxial digital connection---and I would be shocked if it didn't. |
Bronze Member Username: Andyj
Van Alstyne,
TX
United States
Post Number: 15 Registered: Jun-04
| Posted on Sunday, September 26, 2004 - 01:16 am: |
George, I have had this model for several months and it works well- as Gregory noted. However, the first one ( a refurb @ $93) I received was trashed--it would not read mutiple CD's in the changer. It was replaced by H/K --all via email in a short time with no questions asked.
Post Number: 3 Registered: Sep-04
| Posted on Tuesday, September 28, 2004 - 06:27 pm: |
thanks
Bronze Member Username: Brijesh
Budapest Hungary
Post Number: 14 Registered: Jul-04
| Posted on Thursday, September 30, 2004 - 05:25 pm: |
Onkyo has come up a 6 CD changer ... Onkyo CD 360 ... excellent sound for a CD changer ... U might want to give it a try... |
