Thread: Yamaha RX-V650 vs Harmon Kardan AR330 |
New member Username: Mforsland
Post Number: 1 Registered: Sep-04
| Posted on Wednesday, September 22, 2004 - 05:36 pm: |
Can someone give me an opinion on these recievers? I am running all Velodyne speakers and sub.
Bronze Member Username: Bleustar
Pensacola,
Florida
Post Number: 73 Registered: Jul-04
| Posted on Thursday, September 23, 2004 - 08:22 am: |
Features for the Yamaha are at: http://www.yamaha.com/yec/products/RECEIVER/RX-V650.htm Features for the HK are at: http://global.harmankardon.com/product_detail.aspx?Region=USA&Country=US&Languag e=ENG&cat=REC&prod=AVR%20330&sType=C I would buy the HK AVR330 hands down for the superior sound. But the Yamaha does have some nice features that may be more important to you. The sound on the RX-v650 is thinner and brighter than the HK and so I would strongly recommend hearing them both before you make a purchase. |
Silver Member Username: Rh1
Post Number: 147 Registered: Jun-04
| Posted on Thursday, September 23, 2004 - 09:25 am: |
I don't know if the Velodyne speakers you mention are bright/warm sounding, but consider that the H/K is described as warm and the Yamaha is described as bright. What receiver do you have now? |
Post Number: 2 Registered: Sep-04
| Posted on Thursday, September 23, 2004 - 12:00 pm: |
I have a older Harman Kardon which I like alot. The sound is awesome through the Velodynes. They are definetly warm and clean sounding I ended up buying the Yamaha last and I played with it. I like the features but not to impressed with the sound. It seems that the sound is not as dramatic and clean as my older H/K. I am returning it today for the H/K AVR330. Hopefully I will be happy with this one. Thanks all for your help. |
| Posted on Sunday, September 26, 2004 - 03:44 am: |
Hello, I wonder how would you compare these two receivers to go with B&W 309/303/LCR3 combination. I'm mostly into electronical music and movies like Lord of the Rings, I like my bass punchy and so. Thanks. |
Silver Member Username: Landroval
Post Number: 732 Registered: Feb-04
| Posted on Sunday, September 26, 2004 - 04:35 am: |
H/K has definitely a better bass output. It's full and warm, while Yamahas still have slightly weak and thin bass. With B&W's the H/K is a good combination and it'll probably suit better your needs than Yamaha. |
| Posted on Thursday, October 21, 2004 - 11:52 am: |
Hi, I have a similair question but with different models. Looking at buying either the H/K AV230 or the yamaha HTR 5760, does anyone have either of these or any input. Thanks |
Post Number: 310 Registered: Jun-04
| Posted on Thursday, October 21, 2004 - 12:31 pm: |
tlil...Final decision obviously would be your preference. You don't mention what speakers you have so matching between these two receivers is a crap shoot for us so far. Initially H/K without any other info |
