Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through September 21, 2004 > Needed: NAD HTR 2 remote interface ca...
Author Thread: Needed: NAD HTR 2 remote interface cable wiring spec
Username: Dary
São Paulo
Brazil
Post Number: 13
Does anyone know where to get detailed info about conector and wiring for the HTR 2 remote serial cable???
I live in Brazil and the local distributor doesn´t sell the remote inteface.
Thanks in advance.
Dary
Username: Johnny
Missouri
Post Number: 424
Dary,
What do you mean by the "HTR-2 remote serial cable"? What is the connector and wiring you speak of? I have an NAD T762 with HTR-2 remote, but I have never heard of these things. I know you can control the receiver by a computer using the RS-232 port and a normal serial cable, but other than that, you have lost me.
Username: Landroval
Post Number: 706
Johnny, open the battery cover and you'll find the connector.
Dary, sorry no info. What would you like to do with it?
Username: Dary
São Paulo
Brazil
Post Number: 14
Landroval,
I would like to back up the programming I did on the remote. I took me several days to optimize the set up and I don´t want to loose anything if the battery goes off for example. Also, it seems that there are some occasional software updates. Thanks anyway.
Johnny,
The NAD site provides the software and there is also a product including the cable: HTR 2 interface kit.
Regards,
Dary
Username: Johnny
Missouri
Post Number: 425
Yes, I have seen this connector, but I didn't know what it was for. Thats good to know.
Dary,
Try emailing NAD directly and see if you can get one sent to you.
Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through September 21, 2004 > Needed: NAD HTR 2 remote interface ca... [ « Previous ] [ Next » ]
