Home > Message Board > Home Audio > CD Players > Archive through December 11, 2004 > Advice - Best £500 seperates system
Author Thread: Advice - Best £500 seperates system
Username: Agreen
I have around £500-£600 and decided I would spend a little more time and try to find a decent seperates system instead of an all-in-one.
I am after a CD/DVD, tuner, amp, floor standers with the option of using it for 5.1. I know its kind of an open ended question but Im hoping the feeling will be unanimous. Thanks!
Hi Anto,
At that price range i'd seriously consider a stand mount speaker. You get a lot more for your money than with a floorstander. If your looking for 5.1 one day you can always demote the standmounts to the rears at a later date.
If you can go second hand on the Amp and tuner. possibly the CD player as well. Cd player is a bit more risky as the transport mechanism may fail.
Does your budget include cables?
All I can suggest is something like this:
Secondhand Denon DVD700 appox £100
Secondhand Denon AVR1804 AV amp approx £200
Secondhand Pure DRX-701ES Tuner approx £70
Monitor Audio Bronze B2 Speakers - £190 (New)
B1's are cheaper but not quite as good.
Attacama Stands - £40 S/H - Ebay
Interconnects - Allow about £60 or so for 2 interconnects. Stay away from super expensive interconnects. I doubt you'll be able to tell the difference anyway. As for speaker cable try some good quality twin and earth electrical cable before you spend loads on 'Special' cables.
HTH
Home > Message Board > Home Audio > CD Players > Archive through December 11, 2004 > Advice - Best £500 seperates system [ « Previous ] [ Next » ]
