Thread: Wharfedale Diamonds any good |
| Posted on Monday, January 12, 2004 - 11:01 pm: |
Are the Diamonds really a good bet for the money? 4 8.1s a center channel and a sub? ARe there other speakers to consider for a 5.1 set up using a 50 watt HK receiver? |
New member Username: Edison
Post Number: 267 Registered: 12-2003
| Posted on Tuesday, January 13, 2004 - 03:25 pm: |
They are pretty good - the ones with kevlar woofers. Another one you might want to consider is the www.ascendacoustics.com They got raving reviews and are reasonably priced - since they sell direct, cutting out the middleman, they can offer more quality for the buck. You can try it for 30 days and return them. |
| Posted on Tuesday, January 13, 2004 - 08:48 pm: |
Thank you James. I have never heard of these speakers, or heard them, but they are certainly very reasonably priced. Have you listened to them? |
New member Username: Project6
Post Number: 89 Registered: 12-2003
| Posted on Wednesday, January 14, 2004 - 12:30 pm: |
the wharfedales are very nice speakers but they are power hungry and not very efficient. You need a more robust receiver or power amp to drive them, driven by the right equipment they are hard to beat. Now the ascend acoustics are a totally different matter, they have a very nice staging quality and should match well with your HK. cheers |
