Thread: NAD 752 Remote Control |
New member Username: Mca32
Post Number: 2 Registered: 12-2003
| Posted on Monday, January 12, 2004 - 11:08 am: |
My remote control does not control the 752 very often. I have to get right up close and press a button 3 or 4 times. I have a remote control extender I sometimes use (Powermid) but it still won't control the receiver. Has anyone else had problems with the remote control on this receiver? What kind of equipment or extender products do I use to plug into the IR input on the back of it? Any advice would be helpful! I love the sound of my NAD, but being unable to control the volume consistently is giving my system an extremely low WAF, which makes my life miserable. Thanks!
Brockish Unregistered guest |
| Posted on Monday, January 12, 2004 - 11:45 am: |
I would try replacing the batteries first and foremost. Could be lack of battery power. Try that! |
Post Number: 3 Registered: 12-2003
| Posted on Monday, January 12, 2004 - 11:53 am: |
Good advice, but tried it. It's both the NAD remote and the Harmony SST I got. Neither will control the NAD very well, but control all other components just fine. What about different remote extender products? How can I plug into the IR Input on the back of the NAD? |
