Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through January 16, 2004 > Pioneer vsx d407
Author Thread: Pioneer vsx d407
I will be leaving for school in a few days.. I dont want to buy another receiver. My receiver stand-by light comes on.. When I go to power on my receiver nothing powers on... ONLY, my stand-by light is the only thing getting power.. Whats wrong?
bump
Username: Project6
Post Number: 76
check your speaker connections for shorted wires. or if you have been using a lower impedance speakers other than what your receiver is rated for, then you may have caused the receiver into protect mode permanently. Which means, it may have been fried.
What kind of receiver is it?
it is a pioneer... can i usse a multimeter? if so how?
Username: Project6
Post Number: 78
model no.? How old is it?
what kind of speakers are you using...are they 8 ohms or 4
unhook the speaker wires from both ends then use the multi meter for continuity on the wires, if there is...then you have a short.
sept28,1998
I have no speakers hooked..
i checked the fused there not popped or anything..
model vsx-d407
Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through January 16, 2004 > Pioneer vsx d407 [ « Previous ] [ Next » ]
